Removing Clip Warping
If you have applied any warping to a clip, you can remove warping and revert the clip to its original duration. This can be useful if you are not satisfied with the results and want to revert to the pre-warped clip. Warp markers are not deleted when applying the Remove Warp command, but any warping is undone.
To remove clip warping:
1. Select the clip for which you want to remove warping.
2. Do one of the following:
Choose
Clip > Remove Warp.
With any Edit tool, Right-click the clip and select
Remove Warp from the pop-up menu.
Remove Warp can only be applied to clips and cannot be applied to clip groups. To unwarp clip groups you must first ungroup the clip, then apply Remove Warp to the underlying clips, and then regroup those clips.
