Range Warp
Range Warp applies Elastic Audio processing between two fixed points in a clip. To apply Range Warp, there must be at least two Warp markers present in the clip.
To apply Range Warp within a clip:
1. In Warp view, add a Warp marker at the first point that you want to fix to the Timeline.
2. Add another Warp marker to the end point that you want to fix to the Timeline.
3. With the Grabber tool, drag an Event marker between the two Warp markers to the left or right. A Warp marker is added on top of the Event marker and the audio is compressed or expanded on either side of the dragged marker while the audio outside the bounding markers remains unaffected.
Before and after warping, applying Range Warp between two Warp markers in a clip
