Elastic Audio : Elastic Audio Plug-Ins : Elastic Audio Plug-In Window Controls
The Elastic Audio Plug-In window provides a set of controls in the window header that are common to all Elastic Audio plug-ins.
Elastic Audio plug-in controls
• Track Selector
Lets you access any other audio track in the project.
• Plug-In Selector
Lets you select any Elastic Audio plug-in or disable Elastic Audio.
• Plug-In Settings Menu
Lets you copy, paste, save, and import plug-in presets.
• Plug-In Librarian Menu
Recalls Elastic Audio plug-in settings files (presets) saved in the plug-in’s root settings folder.
• Next (+) and Previous (–) Setting Buttons
Lets you select the next or previous preset from the Plug-In Librarian menu.
*You will lose the current plug-in settings if they are not saved before you use the Next and Previous Setting buttons. Save your plug-in settings as presets using the Plug-In Settings menu.
• Plug-Ins Settings Select Button
Accesses the Plug-In Settings dialog, which lists the presets for the current plug-in. From this list, you can select a new preset, or audition a series of presets.
• Compare
Toggles between the original saved plug-in settings and any changes you have made to it so you can compare them.
• Target Button
When multiple Elastic Audio Plug-In windows are open, clicking this button selects that plug-in as the target for any computer keyboard commands. Deselecting the Target button lets you open another targeted Elastic Audio Plug-In window.
