AudioSuite Processing : Conditions for AudioSuite Rendering with Handles, Fades, Clip Gain, and Metadata
Most AudioSuite plug-ins provide several options for rendering clips, but only certain settings let you apply AudioSuite handles. For example, AudioSuite Handles are not available with Entire Selection mode (since the point of this option is to render the whole selection only). Fades and crossfades, and clip gain settings are preserved or rendered depending on the File mode and AudioSuite Rendering mode settings. Additionally, clip metadata can be preserved for rendered clips under certain conditions. The following conditions apply.
Handle creation, and Fade, Clip Gain, and Metadata preservation criteria for AudioSuite rendering
File Mode
Rendering Mode
Handle Behavior
Whole File
Fades
Clip Gain
Metadata
Overwrite File
Clip By Clip
No Handles
Unavailable
Preserved
Preserved
Preserved
Overwrite File
Entire Selection
No Handles
Unavailable
Rendered
Rendered
Preserved
Individual Files
Clip By Clip
Handles created
Available
Preserved
Preserved
Preserved
Individual Files
Entire Selection
No Handles
Unavailable
Rendered
Rendered
Preserved
Continuous File
Clip By Clip
Handles created at the beginning and end of the new continuous file
Unavailable
Rendered
Rendered
Not preserved
Continuous File
Entire Selection
Unavailable
Rendered
Rendered
Not preserved
*Some plug-ins that rely on the Edit selection for processing (including plug-ins that require an analysis pass) may not work as expected when using handles. In this case, it is recommended that the handle length be set to zero.
*Destructive recording and Destructive Punch recording are not supported with AudioSuite rendered clips with handles.
