AudioSuite Processing : Using AudioSuite Plug-Ins : Selecting Tracks for AudioSuite Processing
Because AudioSuite processes are performed on the specific clips that you select, it is important that you select only those clips, or parts of clips, you actually want to process.
*When processing a single audio channel with an AudioSuite plug-in, make sure that the plug-in is set to Mono mode, if available.
