AudioSuite Processing : AudioSuite Window Footer : Render Button : Automatic File Naming of AudioSuite-Processed Audio
When new audio files are created as a result of AudioSuite processing, Pro Tools will auto-name these files according to the type of plug-in used. The name of the clip determines the prefix, while the type of AudioSuite plug-in determines the suffix.
Automatic file naming follows these rules:
• New clips are named beginning with the clip name, followed by an abbreviation of the current AudioSuite process, followed by standard Pro Tools file and clip numbering.
• If a plug-in’s File Mode is set to Overwrite Files, the original clip’s name will not be changed.
• If a plug-in’s File Mode is set to Create Individual Files, the resulting clips will have an abbreviated version of the plug-in name appended to them.
