AudioSuite Processing : AudioSuite Window Footer : Preview Button
Preview Button
The Preview button in the AudioSuite window lets you audition the effect of a plug-in before you process the audio. By adjusting the plug-in controls while you listen to this audio preview, you can fine-tune the effect. Not all AudioSuite plug-ins support previewing.
Before you preview AudioSuite processing, be aware that:
• The performance of the Preview function depends on the speed of your CPU. Faster computers preview AudioSuite effects better than slower computers.
• Regardless of how many tracks and clips are currently selected, the Preview button will audition only the first selected stereo track or the first selected pair of mono tracks.
• In Mono mode, only the first channel of any selected multichannel clip will be previewed.
• If you are processing using Clip-by-Clip mode, the Preview function will preview only the first clip within a multi-clip selection. To hear all selected clips, temporarily select Create Continuous File from the File Mode menu before previewing.
