AudioSuite Processing : AudioSuite Window Header : Use In Playlist Button
This button determines whether AudioSuite processing will replace all instances of the selected clips everywhere in the project, or only the occurrences of the clips that are currently selected.
• Use In Playlist Off
When Use in Playlist is disabled, a new, processed version of the selected clip will be added to the Clips List. No original clips will be replaced or overwritten anywhere in the project.
• Use In Playlist On, Reference = Clips List
When Use in Playlist is enabled and the Selection Reference pop-up menu is set to Clips List, all copies of the selected clip will be replaced everywhere in the project.
• Use In Playlist On, Reference = Track
When Use in Playlist is enabled and the Selection Reference is set to Playlist, only clips selected in tracks in the Edit window will be replaced.
*If the Selection Reference pop-up menu is set to Clips List, the Use in Playlist button will automatically be disabled to ensure that you do not accidentally replace every occurrence of the clip in a project.
