Other AudioSuite Plug-In Utilities : Gain
Gain
The Gain plug-in boosts or lowers a selected clip’s amplitude by a specific amount. Use it to smooth out undesired peaks and other dynamic inconsistencies in audio material.
Gain
• Gain
Specifies the gain amount. Set this value by manually adjusting the Gain slider, by entering a numeric decibel value, or by entering a percentage.
• Analyze
When clicked, displays the peak amplitude value of the current selection.
• RMS/Peak Toggle
Switches the calibration of gain adjustment between Peak or RMS modes. Peak mode adjusts the gain of the input signal to the maximum possible level without clipping. RMS mode adjusts the input signal to a level consistent with the RMS (Root-Mean-Square) value, or the effective average level of the selected clip.
To change the gain of an audio clip:
1. Select the clip whose gain you want to change.
2. Choose AudioSuite > Other > Gain.
3. Adjust the Gain slider.
4. Click Preview to audition your changes.
5. Ensure that Use In Playlist is enabled.
6. Click Render.
