MIDI Editing : MIDI Event List : Opening the MIDI Event List : Columns in the MIDI Event List
Information for the events in the MIDI Event List is displayed in the following three columns:
• Start Column
Displays the start location, using the Main Time Scale, for each event. Locations can also be displayed in the Sub Time Scale when the Show Sub Counter option is selected in the Options pop-up menu.
The playback cursor appears as a blue arrow (red, when tracks are record-enabled) in the Start column.
When several events reside at the same location, the location is only indicated for the top event, with the others dimmed. The dimmed locations can be edited by double-clicking them.
MIDI Event List columns
• Event Column
Displays the event type, indicated by an icon, and associated event values.
• Length/Info Column
Displays the end point or length for notes, depending on which option is selected in the Options pop-up menu. Also displayed are the names for continuous controller events and program changes.
