MIDI Editing : MIDI Editor : Notes Pane Right-Click Menu : Notes Pane Right-Click Menu Options
Formattng for this level of nesting is not currently supported. Tools
The Tools submenu lets you select any Edit tools relevant to the Score Editor.
• Zoomer
Selects the Zoomer tool.
• Trim
Selects the Trim tool.
• Selector
Selects the Selector tool.
• Grabber
Selects the Grabber tool.
• Pencil
Selects the Pencil tool.
• Smart
Selects the Smart tool.
• Zoomer Tools
Lets you select Normal Zoom or Single Zoom.
• Pencil Tools
Lets you select any of the Pencil tools.
Formattng for this level of nesting is not currently supported. Insert
The Insert submenu lets you insert meter changes at the location of the Edit cursor.
• Meter
Inserts a meter change.
Formattng for this level of nesting is not currently supported. Cut
The Cut command cuts the current Edit selection.
Formattng for this level of nesting is not currently supported. Copy
The Copy command copies the current Edit selection.
Formattng for this level of nesting is not currently supported. Paste
The Paste command pastes the clipboard to the current Edit selection or at the current Edit cursor location. Any MIDI notes already present at the same location are overwritten.
Formattng for this level of nesting is not currently supported. Clear
The Clear command clears (deletes) the current Edit selection.
Formattng for this level of nesting is not currently supported. Separate
The Separate command lets you separate MIDI notes at the Edit cursor location.
Formattng for this level of nesting is not currently supported. Consolidate
The Consolidate command lets you consolidate selected multiple consecutive MIDI notes of the same pitch.
Formattng for this level of nesting is not currently supported. MIDI Real-Time Properties
Selecting the MIDI Real-Time Properties option opens the MIDI Real-Time Properties window.
Formattng for this level of nesting is not currently supported. Event Operations
The Event Operations submenu lets you select any of the Event Operations windows (such as Quantize or Change Velocity).
Formattng for this level of nesting is not currently supported. Open in MIDI Event List
The Open In MIDI Event List option opens the selected track in the MIDI Event List.
