MIDI Editing : Writing Real-Time Properties to Tracks or Clips
Once you have found the settings you want, you can write Real-Time Properties to the selected tracks or clips using the Real-Time Properties window. Real-Time Properties are applied to the current MIDI data on the track or in a clip.
To write Real-Time Properties to tracks:
1. Enable Link Track and Edit Selection.
2. Select one or more tracks to which you want to apply Real-Time Properties.
3. Open the Real-Time Properties window (Event > MIDI Real-Time Properties).
4. Select Tracks from the Real-Time Properties Apply To pop-up menu.
5. Configure the Real-Time Property settings.
6. Do one of the following:
*Click the Write to Track button in the Real-Time Properties window.
*Choose Track > Write MIDI Real-Time Properties.
To write Real-Time Properties to clips:
1. Select one or more clips to which you want to apply Real-Time Properties.
2. Open the Real-Time Properties window (Event > MIDI Real-Time Properties).
3. If Link Track and Edit Selection is enabled, select Clips from the Real-Time Properties Apply To pop-up menu.
4. Configure the Real-Time Property settings.
5. Click the Write to Clip button.
To clear Real-Time Properties from a clip:
1. Select the clip for which you want to clear Real-Time Properties.
3. Select Clips from the Real-Time Properties Apply To pop-up menu.
4. Click the Clear Clip Properties button.
