EQ III : 7-Band EQ III : 7-Band EQ III High Shelf/High Peak
The High Shelf/Peak band is switchable between high shelf EQ and high peak EQ functions. By default, this band is set to High Shelf.
• High Shelf EQ
Boosts or cuts frequencies at and above the Frequency setting. The amount of boost or cut is determined by the Gain setting. The Q setting determines the shape of the shelving curve.
• High Peak EQ
Boosts or cuts a band of frequencies centered around the Frequency setting. The width of the affected band is determined by the Q setting.
High Shelf EQ (left) and High Peak EQ (right)
The High Shelf and High Peak Gain controls and their corresponding graph elements are displayed on-screen in blue. The following control values are available:
Control
Value
Frequency Range
1.8 kHz to 20 kHz
Frequency Default
6 kHz
High Shelf Q Range
0.1 to 2.0
High Peak Q Range
0.1 to 10.0
Q Default
1.0
High Shelf Gain Range
–12 dB to +12 dB
High Peak Gain Range
–18 dB to +18 dB
