EQ III : 7-Band EQ III : 7-Band EQ III High Mid Peak
The High Mid Peak band boosts or cuts frequencies centered around the Frequency setting. The width of the band is determined by the Q setting.
High Mid Peak EQ
The High Mid Gain control and its corresponding graph elements are displayed on-screen in green. The following control values are available:
Control
Value
Frequency Range
200 Hz to 18 kHz
Frequency Default
2 kHz
Mid Peak Q Range
0.1 to 10.0
Mid Peak Q Default
1.0
Mid Peak Gain Range
–18 dB to +18 dB
