EQ III : 7-Band EQ III : 7-Band EQ III Mid Peak
The Mid Peak band boosts or cuts frequencies centered around the Frequency setting. The width of the band is determined by the Q setting.
Mid Peak EQ
The Mid Gain control and its corresponding graph elements are displayed on-screen in yellow. The following control values are available:
Control
Value
Frequency Range
125 Hz to 8 kHz
Frequency Default
1 kHz
Mid Peak Q Range
0.1 to 10.0
Mid Peak Q Default
1.0
Mid Peak Gain Range
–18 dB to +18 dB
