EQ III : 7-Band EQ III : 7-Band EQ III Low Mid Peak
The Low Mid Peak band boosts or cuts frequencies centered around the Frequency setting. The width of the band is determined by the Q setting.
Low Mid Peak EQ
The Low Mid Gain control and its corresponding graph elements are displayed on-screen in brown.
The following control values are available:
Control
Value
Frequency Range
40 Hz to 1 kHz
Frequency Default
200 Hz
Low Mid Peak Q Range
0.1 to 10.0
Low Mid Peak Q Default
1.0
Low Mid Peak Gain Range
–18 dB to +18 dB
