EQ III : 7-Band EQ III : 7-Band EQ III High Pass/Low Notch
The High Pass/Notch band is switchable between high pass filter and notch EQ functions. By default, this band is set to High Pass Filter.
• High Pass Filter
Attenuates all frequencies below the Frequency setting at the selected slope while letting all frequencies above pass through.
• Low Notch EQ
Attenuates a narrow band of frequencies centered around the Frequency setting. The width of the attenuated band is determined by the Q setting.
High Pass filter (left) and Low Notch EQ (right)
The High Pass and Low Notch EQ controls and their corresponding graph elements are displayed on-screen in gray. The following control values are available:
Control
Value
Frequency Range
20 Hz to 8 kHz
Frequency Default
20 Hz
HPF Slope Values
6, 12, 18, or 24 dB/oct
Low Notch Q Range
0.1 to 10.0
Low Notch Q Default
1.0
