EQ III : EQ III I/O Controls : Input and Output Meters
(7-Band EQ Only)
The plasma-style Input and Output meters show peak signal levels before and after EQ processing, and indicate them as follows:
• Green
Indicates nominal levels
• Yellow
Indicates pre-clipping levels, starting at –6 dB below full scale
• Red
Indicates full scale levels (clipping)
When using the stereo version of EQ III, the Input and Output meters display the sum of the left and right channels.
The Clip indicators at the far right of each meter indicate clipping at the input or output stage of the plug-in. Clip indicators can be cleared by clicking the indicator.
