Click Beat Value
If the Follow Meter option is disabled, you can manually set the rhythmic value for the downbeat click. If the Follow Meter option is enabled, the Click Beat Value options grayed out.
To set the Click Beat Value independently of the Meter track:
1. Ensure that the Follow Meter option is disabled.
2. Click to select a rhythmic value for the downbeat click (whole, half, quarter, eighth, or sixteenth note).
3. Click to select (or deselect) the triplet or dot modifier for the beat value.
The Click Beat Value options can be automated to support the appropriate accent patterns for different meters for the click.
