Clip Loops and Groups : Unlooping Clips
Unlooping Clips
Unlooping and Flattening Looped Clips with Separate Clips Menu Commands
To unloop a looped clip:
1. Select the looped clip.
2. Do one of the following:
*Choose Clip > Unloop.
*Right-click the clip you want to unloop and select Unloop.
3. Do one of the following:
*Click Remove to unloop and remove all loop iterations except the first full loop iteration (source clip).
*Click Flatten to unloop and create individual clips from each loop iteration.
*Clip Ungroup functions on loops the same as using the Unloop command and choosing Flatten.
To unloop and ungroup a selection down to its individual clips:
1. Select a looped clip that contains one or more clip groups.
2. Choose Clip > Ungroup All.
