Memory Locations : Copying Marker Memory Locations
To copy and paste a range of Markers:
1. If you want to constrain the selection to the current Grid value, set the Edit mode to Grid.
2. Drag in the Tempo ruler to select the range of measures that includes the Markers.
If the beginning of the selection includes a Marker, press Command (Mac) or Control (Windows) so the Selector tool appears.
*Press Option (Mac) or Alt (Windows) while dragging to select across all Conductor tracks.
3. Choose Edit > Copy.
4. Click in the Markers ruler at the point where you want to paste the tempo events.
5. Choose Edit > Paste. The contents of the Clipboard are pasted from the insertion point, replacing any existing Markers.
To extend an Edit selection in a track to the Markers ruler:
1. Using the Selector or Grabber tool, select a track range.
2. Shift-click in the Markers ruler. Shift-click again in the Markers ruler to remove it from the selection.
To select all Markers in the Markers ruler:
*With the Selector tool, double-click in the Markers ruler.
