Editing Memory Locations
Memory Locations can be renamed, edited, deleted, and copied and pasted.
To rename a Memory Location:
1. Do one of the following:
In the Memory Locations window, double-click the Memory Location to open the Edit Memory Location dialog.
In the Marker ruler, double-click the Marker to open the Edit Memory Location dialog and relocate the insertion point at the marker location.
In the Marker ruler, Control-click (Mac) or Start-click (Windows) the Marker to open the Edit Memory Location dialog without locating the insertion point at the marker location.
2. Enter the new name for the Memory Location, and click OK.
To redefine the General Properties stored with a Memory Location:
1. Make changes to the project’s zoom settings, pre- and post-roll times, Show/Hide status of tracks, or Track Heights.
2. Do one of the following:
3. In the Memory Location dialog, select the General Properties you want to save with the Memory Location.
4. Enter a name for the Memory Location and click OK.
To change a Memory Location from one type to another:
2. In the Memory Location dialog, select either Marker, Selection, or None as the Memory Location type.
3. Enter a name for the Memory Location and click OK.
To change the Selection stored with a Memory Location:
1. Select a range of material in one or more tracks.
2. In the Memory Locations window, Control-click (Mac) or Right-click (Windows) the Memory Location that you want to redefine.
To move a Marker by dragging:
In the Markers ruler, drag the Marker left or right.
If the Edit mode is set to Grid, the dragged event snaps to the current Grid value. If using Spot mode, the Spot dialog opens.
To align a Marker to a different location:
In any of the Timebase rulers, click with the Selector tool at the new location.
Click in any track. To align the Marker to the start of a clip, select the clip with the Grabber tool.
2. In the Memory Locations window or the Markers ruler, Control-click (Mac) or Start-click (Windows) the Marker Memory Location that you want to redefine.
3. Enter a name for the Marker and click OK.
