Time, Tempo, and Meter : Change Meter : Change Meter Options
Options for the Change Meter command include:
• New Meter
Lets you specify a new time signature. The first field lets you enter the number of beats (up to 99) in a measure, and the second field lets you enter the note length that counts as one beat.
• Click
Lets you specify the note value that will trigger the metronome click. For example, if an eighth note is chosen, a click is played for every eighth note, regardless of tempo.
• Starting at Bar
Sets the bar where the meter change is added. Meter changes made in the Change Meter page can only be made at the beginning of a bar.
• Apply Change To
Lets you apply the meter change to the selected range, to the end of the project, or until the next bar.
• Change
The Change fields let you specify the number of bars of the new meter that you want to have replace the selected range.
Pro Tools automatically calculates the nearest whole bar number, or you can specify a number of bars to be affected. Time is inserted or deleted, in whole bar increments, at the end of the selection, as necessary on all affected tracks when you override the calculated range.
