Editing Meter Events
Existing meter events can be edited, deleted, copied, and pasted.
To edit a meter event:
1. In the Meter ruler, double-click the meter event.
2. In the Meter Change dialog, enter a new Location or Meter for the event.
3. Click OK.
To delete a meter event:
Option-click (Mac) or Alt-click (Windows) the meter event.
To copy and paste several meter events:
1. If you want to constrain the selection to the current Grid value, set the Edit mode to Grid.
2. Drag in the Meter ruler to select the range that includes the meter events.
If the beginning of the selection includes a meter event, press Command (Mac) or Control (Windows) so the Selector tool appears.
Press Option (Mac) or Alt (Windows) while dragging to select across all Conductor tracks.
3. Choose Edit > Copy.
4. Click in the Meter ruler at the point where you want to paste the meter events.
5. Choose Edit > Paste. The contents of the Clipboard are pasted from the insertion point, replacing any existing meter events.
To extend an Edit selection in a track to the Meter ruler:
1. Using the Selector or Grabber tool, select a track range.
2. Shift-click in the Meter ruler.
Shift-click again in the Meter ruler to remove it from the selection.
To select all meter events:
With the Selector tool, double-click in the Meter ruler.
To clear a range of selected meter events:
2. Drag in the Meter ruler to select the meter events you want to remove.
3. Choose Edit > Clear to delete the selected meter events.
