Time, Tempo, and Meter : Tempo Operations Window : Parabolic
Parabolic
The Parabolic page in the Tempo Operations window lets you create tempos that accelerate or decelerate by following a tempo curve, which changes the tempo more rapidly or less rapidly over the selection time.
Parabolic page (Advanced Option)
• Advanced
When this option is selected, the selection range changes to the Main Time Scale format, and additional and modified options become available.
• Calculate (Advanced Option)
Calculates the selection end time, the start tempo, the end tempo, or the curvature of the tempo change.
• Selection Start and End
Displays the start and end points for the tempo change in the currently selected Main timebase. When an Edit selection is made, the Start and End fields will display the selection boundaries. Changing start or end values changes the selection range.
• End Time (Advanced Option)
Displays the absolute time for the selection end. When the Main Time Scale is set to Bars|Beats, the end time is displayed in the Sub Time Scale. When the Main Time Scale is set to any absolute timebase, the end time is calculated and displayed in Bars|Beats. Changing the end time value causes the tempo to change.
• Tempo Start and End
Displays the tempo, in beats per minute (BPM), for the start and end points of the selected range. Changing the tempo causes the end time value to change.
• Curvature
Specifies and displays a numerical and graphic representation of the tempo curve. Negative numbers indicate a more rapid tempo change at the beginning of the time range, and positive numbers indicate a more rapid tempo change at the end of the time range. This value can be set with the Curvature slider.
• Resolution (Advanced Option)
Lets you select the BPM note value for your tempo setting.
*Selecting “Follow Metronome Click” will set the tempo BPM note value to mirror the click value set in the meter markers.
• Density (Advanced Option)
Lets you specify the density of the tempo change events written to the Tempo ruler.
• Preserve Tempo after Selection
If selected, the previous tempo setting that was in effect at the selection end point is preserved after the selection. If unselected, the last tempo event created by the tempo operation continues to the end of the project, or until the next tempo event beyond the selected range.
