Hardware and System Specs
Power Consumption:
CM408T Channel Strip Module
- Integral 300 WATT PSU
- Input: 100 – 240 VAC, 50/60 Hz
- DC Outputs: +5V @ 40 Amps, +12 V @ 8 Amps
- AC Input Connector: Chassis mounted IEC with
- On/OfF Switch
- Typical Power Consumption 150 Watts
MC
- External Table Top 150 Watt PSU with On/OFF Switch
- DC Outputs: +5V @ 15 Amps, +12 V @ 8 Amps
- Input: 100 – 240 VAC 50/60 Hz
- Typical Power Consumption 80 Watts
- AC Input Connector: IEC with On/OFF Switch
- DC Output Connector: 19 Pin Locking Circular
MC Hardware Features:
- Touch Screen VGA Output (1024x768)
- Keyboard and Mouse Serial Inputs
- Keyboard connectors are in tray both USB and PS-2
- USB 1.1
- 100 MB Ethernet (IEEE 802.3) Connector: EtherCon RJ45
- 1/4” Stereo headphone in (back) pass through to out
- (front)
- 1/4” footswitch programmable from touch screen
- VGA output of touch screen
- Integral phantom powered electret talkback microphone
- 65 programmable SmartSwitches
- 9 Rotary Controls with Display Rings for Plug-In control
- Backlight brightness controls
- 3 eight segment and 1 four segment displays in mon section
MC Data Storage:
- Internal Hard drive
- USB port on the MC for external USB drives
- Files can be stored on the host workstation via
the network
MC Overall Size:
- 37.5” (952.5mm) wide, 20.7” (526mm) deep,
- 3.6” (91.5mm) high - 36” (914.5mm) wide without end caps
MC Weight
Environmental
- Ambient Temperature Operating: +5°C to +35°C
- Non-operating temperature: –40°C to +70°C
- Operating Altitude: –100 to 10,000 ft.(–30 to 3,048 m)
- Relative Humidity: 20% to 85%, non-condensing
Recommended Height:
- MC should be positioned so the user’s forearms are horizontal when fingers rest on the keyboard.
- Specifications and features are preliminary and may change without notice.
