Each channel has an insert point which can be placed in any of the seven process positions. The Avid converters provide analog and digital I/O for insertion of any type of device, such as a delay line, into the signal path.
There are 7 processing sections:
These can be arranged in any order using the eMix application, even when passing audio, but must be re-ordered at least two adjacent channels at a time. For example, the EQ may be set to follow dynamics, the insert may be placed after the EQ or dynamics, and metering, can be placed after the fader, on channels 1 and 2, or on channels 1-8.
Order of Processors
These can be arranged in any order. For example, the EQ may be set to follow Dynamics, the Insert may be placed after the EQ or Dynamics and Metering can be placed after the Fader.
