Internally, S5 Fusion uses MADI to route and patch digital audio. MADI is a very stable and robust AES sanctioned format that allows up to 64 channels of digital audio (at 24-bit, 48kHz) along a single coax cable.
To interface to analog and other digital formats such as AES/ EBU, Avid provides a full range of high quality converters in multi-channel, 19” rack mounting cases. The standard S% Fusion package includes an MA703 for analog monitor feeds.
All signals such as Aux sends, mix minus/group outputs, mix outputs, channel inputs, inserts and dynamic key inputs are MADI and require the Avid converters for analog or AES/ EBU connection. Commercial MADI converters are also available including PCI cards for connecting MADI into and out of PCs.
Because the system is modular, it is easy to start working with the S5 Fusion in an analog environment and then add digital converters in future as more of the facility’s sources move to digital.
AM713 Analog to MADI Converter
26 balanced analog on XLR plus an AES or S/PDIF pair to MADI.
MA703 MADI to Analog Converter
MADI to 26 balanced analog on XLR plus an AES or S/PDIF pair
- included in the S5 Fuson package.
DM714 AES/EBU to MADI Converter
13 AES/EBU pairs on 110ohm XLR, or 75ohm BNC, with two extra
analog balanced inputs plus an AES or S/PDIF pair to MADI.
MD704 MADI to AES/EBU Converter
MADI to 13 AES/EBU pairs on 110ohm XLR or 75ohm BNC withtwo
extra analog balanced outputs plus an AES or S/PDIF pair.
MI715 Analog to MADI Converter
16 balanced analog line level inputs and 8 AES/EBU digital inputs
MO705 MADI to Analog Converter
MADI to 16 balanced analog line level outputs and 8 AES/EBU
digital outputs plus an AES or S/PDIF pair.
ML530 Remote Mic Preamp
24 remote controlled mic preamps with XLR inputs. Usually supplied
with AM713 Analog to MADI converter. The mic preamps
are controlled remotely using TCC serial control from the SC264
Studio Computer.
