SC264D Studio Computer
The new SC264D Studio Computer runs the eMix software
which includes the file management system and the PatchNet
software. It includes twin drives set up as a RAID array for redundant
storage of all data. There is a separate keyboard and
mouse for this computer that fits under the console and an external
screen for showing the eMix software at the top of the
Joystick module.
The SC264D includes an Ethernet port for connection to the S5
Fusion LAN and is fitted with two controller and up to 2 DSP cards:
- EUCON Hybrid PCI Card - Control up to 5 workstations
- TT002 card for machine control, including a single RS422
port, MMC port, video ref plus 32 GPIO for use with the
console the events system
- Up to two SP663 DSP Cards
The DSP Cards provide:
- DSP Processing - Massive amount of scalable DSP available
for fully featured channels and Buses with Delay, EQ
& Dynamics processing. Each SP663 card adds 5.5 GFLOPS
of processing power
- MADI I/O - each SP663 card adds 4 MADI inputs and outputs
(256 x 256 paths at 48kHz)
- Router controlled by the console’s PatchNet Software
- Up to 116 full featured Channels at 48kHz - 2 x SP663 Cards
- 96kHz operation with 50% less dsp channels
- Independent EQ, filters and dynamics processing per channel
- Up to 2 seconds delay per channel
- Bus processing with dynamics and filters
- 4,096-path FPGA audio router on each SP663 DSP card
- Up to 8x8 MADI I/O (512x512 paths @ 48kHz)
- Hardware compatible with 192/384 kHz
- DSPs support 40 bit, 32 bit IEEE floating point and 32 bit
fixed point formats
- Hybrid FPGA and DSP technology to accommodate 40 bit
floating point (extended precision) operation, for timing
precision, and wide feature set
- Parallel signal processing utilizing SIMD (Single Instruction
Multiple Data) architectur
Channels, Mix, Aux and Group Bus Numbers for Multiple SP663 Cards
