EQ and Filters may be adjusted from the channel and the Superchannel. The full EQ controls in the central Superchannel are shown opposite (slightly less than full size).
The EQ is four band fully parametric with switchable peak/shelf on the high and low band.
Each band has frequency (20Hz - 20kHz), gain (+/- 24dB) and Q control.
In each band the Frequency/Q page key toggles the control between frequency and Q, although the knob displays both frequency position and the Q.
There are two filters that can each be set to:
Each filter has a frequency control. The notch filter has a boost/listen function and variable Q.
