Channel Signal Path & Features
160 channel signal paths, up to 32 main/subgroup buses, up to 24 Clean Feed/Group Matrix outputs, up to 24 Aux sends and 24 External Inputs, plus a dedicated mix minus and insert per channel.
Each channel has:
- 2 inputs either A, or B, or A+B
- remote mic preamps may be added to either or both inputs
- phase
- input trim
- delay
- insert send & return
- 4 band fully parametric EQ
- 2 filters
- compressor/limiter or expander with side chain input
- dedicated n-1 mix minus per channel with dedicated output
- up to 24 aux sends (nameable) individually pre or post, mono or paired as stereo
- pre fader direct output
- post fader direct output
- multi-format panner
- up to 24 clean feeds
- up to 32 main program/subgroup busses
- PFL, APL and SIP solo modes
